I emailed the photo to them, got a reply saying it's been passed to the product manager. I checked a couple of other sizes, the 6A is marked "6A - 20A" and 32A "25A - 32A". The 32A lead is thinner than that on the 40A so could just be a labelling issue.
Finally a definitive answer from Hager giving the sizes of the neutral leads that should be fitted. Apparently it should be 4mm2 CSA on the 40A. The swaged end is more or less rectangular in cross section and I measured it at 3.1 x 1.7 mm. If I round that down to 3.0 x 1.6 then that's a 4.8mm2 CSA so it looks like it's the correct lead, in spite of the marking.
Quote from the product manager
By the way, the cable shouldn’t be printed “32A max” because it is confusing.
Disappointing it took so long, and took a few incorrect responses as well, for example their first response was that the same gauge cable was used on all sizes, which is clearly not the case, or not always the case.
