It can be if
(1) existing taps cannot cope with higher pressure,
(2) showers can be painful to the skin
(3) water can "bounce" out of wash basins when the taps is opened too far.
When a combi boiler goes faulty you do not have the back up of an electric immersion heater to provide hot water.
I agree low pressure taps can be affected by high pressure. Pressure reducing valves are available.
Showers being painful? Reduce the flow rate or fit a multi patterned head. Or pressure reducer.
Water bouncing out of basins, reduce the tap flow. Run as slow as possible and the water wasted will be reduced, handy if you're on a water meter. Or fit a pressure reducer.
The intergas mentioned can be turned into a water heater if the pump goes faulty, and you have to wait for a replacement. As can all the other intergas boilers.
Cylinders are a good option if you will used the stored hot water daily or have 2 or more bathrooms. Have baths or do lots of pot washing by hand.
