5 Core SWA
29 Aug 2009
Kent
HI
I'm looking to lay a temporary power supply for two gazebos spaced at 5 meters apart. They run two sets of lights but need switching from 10 meters away here's the question
Can i use 5 core SWA for this with the earths connected to both gazebos??
Jake
seems a bit ott to me.
why not run a 3core to 1st one and link on to second one with 2core?
As only running total of 4 lights common N's, SWA earths common anyway.
one core sw-line to 1st set, other core to second set,
just sleeve cores for correct use ie sleeve black in 3 core with brown,
sleeve grey with blue
there you go Roberts yer Muvver's Bruvver!
Jake why not buy all 3 core, it's on same site and has to be cheaper than 5 core, still got N and 2 sw-lines.....
use imho a 'pratley' 3way jb in 1st Gazebo which carries earth through and gives term for earth core of lights.
see www.qvsdirect.com part #pr08042 (also available elsewhere)
regards
HI
OK thank you i will do that them pratleys are cheaper than TLC
Jake
