I certainly upset you Mick. But no I am not ****ed of with you as you say in your post, just trying to correct things a little. Yes I am a bricky.
Mick Leek said:
What would have you done 150 years ago before b****y electricity was invented never mind laser levels.
As I mention, water levels, or if your an experienced bricky, with a 1200mm level, but believe me, someone with out experience getting things level over a big distance, will "let the bubble go past in the morning and let it come back in the afternoon" Things will start going wrong pretty quick, so a water level is the best.
Mick Leek said:
If you read the guys original post you will read that he has already stated that he has set his levels and so on. I am NOT a b****y brickie, but i still managed to build my own extension. Im simply trying to give the guy a bit of advice seeing no one else want's to.
Untrue Mick, levels have not been said they are set. As for advice, I have
replied to Carry's other posts and we have all had a good discussion on other subjects.
Mick Leek said:
I am simply trying to say that brick laying can be done by most people "all be it slowly" but if you have a simple bit of common sense then it isn't difficult.
Bricklaying can be done by most people if they take their time and want to build a little flower border or a barbeque, but we are talking about building up to dpc on an extension, without prior experience, and, the original post states by going on a 5 day course is this feasible? I think not, you state your trying to save him money, well by doing foundations and footings without experience or someone who knows to help, will end up costing money, and with posts that are not quite right, WILL lose him money. You state about building corners
and running in. Ok this is correct if your above dpc and running in the superstructure, when the slab and dpc is level, then we are laughing. This is about footings UP to dpc, different ball game, Datums must be set around the proposed dwelling, for a level dpc, we are gauging DOWNWARDS so our top two courses will come nice and level to the dpc.
Not to mention, this has to be done in a trench, which is more awkward. It has to be set out SQUARE, using the 3:4:5 method, again in a trench. DIAGONALS have to be checked.
You mention build one corner, then build another, How in a trench without it setting out properly, do you know that your bricks will run linear gauge? Eg from one corner, starting at a stretcher, 20 bricks 4490mm. We don't want cuts in the runs, it looks awful. Also the original post states to get the "pros" in, Believe me they WILL not be happy if this is not all done correctly, again if its not, they will charge a higher price to get out of the problems.
Oh and also theres no need to swear, and as for saying its your last post, thats what I would expect from my 13 year old son
