tawelfryn said:I certainly upset you Mick. But no I am not p****d of with you as you say in your post, just trying to correct things a little. Yes I am a bricky.
Well chaps I started this topic, no offence was meant
I don't want to get personal, I'll say this I think this forum is a great place for discussion and answering queries. Trouble is, it worries me when even the 'pros' argue about what you should do! I think it boils down to there is frequently not just one solution to a problem. Don't forget Mick is now the proud owner of an extension all built by his own hands.
I feel I've had a number of "knock backs" already in my short time here in the forum, but what the heck! I probably haven't phrased my questions in the best way to inspire confidence.
I'm a bit puzzled as to how hard the pros think it is to lay foundations?
Here is a break down of what I intend to do to mark out footings etc. step by step:
I am Assuming I have the necessary planning permission BC etc. Plans have strip footings 600mm x200mm and for sake of argument it's a simple rectangular side extension.
Steps:
1. Inform BCO that I am commencing digging.
Measuring: I'll measure the outside perimeter of the footing first.
2. Measure on the existing house wall where the extension meets. The new cavity wall is 280mm wide so the trench will need to be 160mm wider on both sides of the bricks/blocks to make 600mm. Place a peg in ground against the wall (or fix string to wall with a bent screw/nail) and run string out several metres. Then get the 3:4:5 square (or equivalent) and hold against the wall and align the string so it is perpendicular to the wall, place a peg at far end. This gives me a nice square line to work from.
3. Measure the first wall dimension along that line and place a peg.
4. Place the square along the string and align. Then place another string perpendicular to the first and run out several metres.
5. Measure the second dimension of the wall.
6. And so on until i meet the wall again.
7. There is the possibility of compound error by taking measurements off measurements. So the alternative for the other two sides would be to measure from the other end of the wall and repeat steps 2-5. Hopefully the two ends should meet.
8. To double check everything is square measure the diagonals, they should be identical. And to triple check the diagonal is what it should be you can use pythagoras's therom SQR (a^2 +b^2) eg. If the dimensions are 2000mm x 3000mm the diagonal should be 3606mm.
9. I then need to mark out the inner perimeter 600mm parallel to the outer.
10. I've got quite good building ground as approx 700mm down you hit solid limestone bedrock. So I'll dig down to that level.
11. Once the trench is dug, I'll use a laser level to measure how level the trench bottom is (I could use the DPC as my reference and put the laser at that level. By holding a length of wood perpendicular to the trench bottom place a mark on the wood where the laser strikes. Move the wood around the trench especially the corners. If all is level the laser should interesect at exactly the same point. If not dig a bit more.
12. To make building upto DPC level simple without having to cut blocks etc. I'll take a vertical gauge down from the DPC. If my trench is 900mm deep from the DPC and I need at least 200m depth to the concrete that leaves approx 700m to fill with blocks. If the std block is 215mm in height
2 blocks will make 450 (i.e. 215x2 +10mm mortar x2). Then using 3 courses of engineering bricks (std 65mm+10mm mortar) build up to the DPC. i.e. 2 course of blocks and 3 course of bricks will make 675mm So I'll make the footing 225 deep. i.e. 225+675=900mm
13. One way to mark the fill level is to bang steel pegs (reinforcing bars) to the required concrete depth. (Double check the pegs with the laser level again. )
13. Inform BCO and have him check the footing are deep enough etc.
14. Order the ready Mix. Foundations generally use 1:3:6 I'll ask the BCO what mix he suggests as some ground conditions can affect concrete.
PHEW, I'm glad that's over. I'm writing this around midnight so I may have made a minor error in my calculations but I think all my logic is there. Hopefully I have shown I KNOW what I'm doing and not some 'DIYer from Hell'. Tawelfryn et al may do it differently, but if it works then that's all that matters.
Mick Leek said:I am simply trying to say that brick laying can be done by most people "all be it slowly" but if you have a simple bit of common sense then it isn't difficult.
I couldn't agree more Mick! If you have vertical and horizontal gauges, spirit level, laser level, Square, maybe even a homemade manometer, consistant mortar mix, pointing tool, string line, Bolster chisel, measuring tape, trowel, etc, etc and LOADS of time then I can't see how you can go wrong.
You made a grand job Mick and I'm proud of your gumption. Please don't stop posting, your first hand knowledge is invaluable.
Best wishes
CarryOn
