Indeed, but how safe is everything whilst the genny is running? It'll take a while to heat a cylinder full of cold water.david and julie said:Ban-all-sheds..... I had more in mind warming water in the cylinder then turning generator off, once water is hot it will last all day. I should off said that really.
I have feeling that he's doing all this in France. If FWL is right, they'll just string some jumpleads from the nearest overhead cables for him....plugwash said:if you are having a new supply from the rec anyway i doubt it will cost a huge amount extra to have it temporerally connected to a builders supply unit then moved to the house when its ready
ban-all-sheds said:Maybe I'm being paranoid - do generators come with an earth rod and an RCD? A means of testing how good an earth you've got?
ban-all-sheds said:Yes... but... the pipework may be earthed via the incoming water supply. The bathroom may not be an earth-free environment.
Still - it's all speculation.
Does that mean that the generator will become a permanent part of your supply?Tony6 said:Thanks for all your help on this .
The generator has its own earth terminal which is connected to a earth rod.It also has a rcd built in .
The problem is that the eletric supply is indead very expensive in france and at the moment there is no need for anything greater than 6kw.So i took the option of buying a generator 5kw .
If you could it would be about as much use as a Kleenex condom....I did not realise than i could not buy a electric shower below 7.2kw,for some reason i though i could buy one.
