Monday
Thank you so much for your post! Exactly what I've been looking for is an informed opinion from a structural engineer rather than an electrician.
My lounge is located on the corner of the house with 2 external walls, the side one of which is the one that has been chased. So it is the inner leaf of a cavity wall.
I was hoping to go a bit beyond standard steel conduit and put in square section 50mm x 50mm tubular steel reinforcing bar, with the cables run up the middle. I can get this fabricated from 5mm thick steel. I will fill around it with cement as you suggest.
What's most reassuring is that I had some discussion earlier with a structural engineer, explaining in detail what I had done, and his answer was exactly the same as yours.
