a1topdog said:AL-min said:the car will need to be plugged into "VAGCOM" to identify the nature of the problem
Al
I have VAGCOM and it is not picking up any faults !!
Which VAGCOM are you using? The earlier software will only pickup basic errors on the later vehicles!
secure spark, the reason you are being told this by a non vw dealer is because he will not have VAGCOM, the control unit will have to be set by this software as it is not a plug and play (so to speak). I would say that the reason that your interior circuit is blowing fuses is because that the CAN system uses common wiring sending different signals down that wire, as you control box has gone down its sending confusion into the circuit
pipme, yes it is all a bit of a rip off BUT its not the manufacturers fault. All cars built & sold in Europe have to comply to EOBD1/2 (European On Board Diagnostics).
