6 inch gas pipes
Is that a matter of purging it with nitrogen before the gas?
Explain :confused:
Nitrogen is for purging the gas, this is a new install so not needed.
Just re-looked over the quote, it was 300m of 4 inch, not 400m, so hopefully that'll just mean it needs to be 4 sections, which we have already accounted for. Weve already looked up the costs for pipe etc, the only thing we are not sure about at the moment is lifting the pipe into place. Maybe itll be cheaper to work with 3 metre flanged sections off of a scissor lift, than 6 metre sections needing specialist lifters? Any advice from people who have done this would be appreciated
chrishutt said:
On a DIY forum? :eek:
I know of at least one on here and two on Argi that doit for a living Chris :rolleyes:
Problem is the OP hasn't got back to him. :confused:
kevplumb said:
should be novel listening to him trying to work out the purge volume and the allowed leakage ;)
Didnt actually read my post did you. lol
Maxxy said:
I will then be looking to use a Corgi registered gas person to do the final connections to the heaters, and to purge the system and run all the checks.
Doitall has been really helpful, so as far as im concerned the topics dealt with, and ive made a new work contact :D
Volumn is 9 and 20 cubic decimeters per meter respectively.
Therefor, 40m x 150mm = 0.77 m³, and 100m x 100mm = 0.9m³.
Permitted leak is zero. :LOL:
