Just plumbing in a new downstairs WC in a small extension. Stud walls are up, water feed is connected up and ready to supply the toilet and washing machine but I've hit a bit of a problem working out how to deal with waste from the toilet...
The toilet will be backed up against the rear of the house, with waste needing to exit 90 degrees to the right and straight to the outside where the existing soil stack is.
To the rear and right of the toilet is the water supply to the extension which I will box in (as you'll see on my simple diagram attached), but this means it may be in the way of the waste pipe so I've opted for a flexible waste pipe by McAlpine.
If I go for the attached, what do I need to connect this up to a standard 4" waste pipe which will be going through the cavity and connected up with a boss to the existing soil pipe?
https://www.screwfix.com/p/mcalpine-macfit-mac-8-90-wc-short-pan-connector-white-90-112mm/89461
