I have various DC-powered devices (guitar effects pedals and related gear). They are powered with 9V, 12V or 18V centre-negative DC power supplies. I also have AC-powered amplifiers that I have built myself. Yesterday, for the first time I can recall, I felt a mild shock/tingle when touching the chassis of an amplifier (which is metal and connected directly to ground via the earth wire of its power cable) and a metal part on one of the guitar effects pedals.
I’ve been trying to work out what’s going on ever since. (Below, when I say “true earth”, I generally mean I stuck a multimeter prong into the earth prong of a wall outlet.)
I know the amp chassis is grounded properly. I get multimeter beep continuity between the amp chassis and true earth. I measure zero DC or AC potential between the chassis and true earth.
However, sometimes (but not always…) I can measure 80-100V AC potential between the amp chassis on the metal part of the (DC-powered) effects pedal. I assume this is what’s causing the tingle.
I think that, by design, the effects pedal cannot be properly grounded, because it is powered by a two-pole DC barrel plug which in turn is powered by a wall-wart power supply that has a plastic earth prong.
In fact, if I measure AC voltage potential between either prong of the DC power adapter (when plugged in) and true earth, I get 90V AC consistently. I don’t fully understand this, but I am guessing it has to do with the way the DC power adapter turns AC into DC without a reference to earth? (I have done this test - one prong in the earth of a wall outlet, the other on either pole of the 9V DC plug – in different parts of the house, and it always measured 90V AC).
Then, I had the effects pedal unplugged and I felt another tingle. So I measured, and for a time I had 90V AC between that and true earth even when it wasn’t plugged in. I can’t get my head around how that happened, and it isn’t always like that.
The only other thing I can think of perhaps being relevant, is that both the amp and the power supply for the effects pedal are plugged into the same 4-gang extension lead, which has “surge protection” and a single physical on/off switch.
I’d love some help to understand what’s actually going on here. There’s a part of me that thinks something must be wrong with the wiring in the house but there‘s no other reason to think so (and I have used wall socket tester to look for ground faults or reversed live/neutral and it comes up fine).
Thank you,
Martin
