Will see if turning up the heating can reduce some of the humidity meanwhile. Some articles say that it reduces energy cost to turn on the radiators only when you use the rooms, instead of having it on low settings all the time, but I guess that doesn't help keep the house dry in general.
That is generally false economy, especially with gas central heating. If you heat one room, heat will escape to the rest of the house anyway and it will not make it that much cheaper to run, which is where TRV's come in, so you can set individual temperatures in different rooms. Good insulation and good measures to limit moisture generation inside the house, are the key to low running costs/ a warm home free of moulds.
