Hi
I’m looking for some advice regards a boiler that was installed in my house 2.5yrs ago.
The boiler is an Vaillant Ecotec Exclusive and the house has 4 bedrooms, 1 bathroom, 2 ensuite shower rooms and a gas hob.
When we bought the house as a new build (built by a very small time developer from other side of the country), the gas engineer commissioned the system and we were issued with a Corgi certificate soon after completion. Immediately I took out a British Gas homecare agreement and on subsequent yearly checks, the BG engineers have pointed out that the gas pressure feed is a couple of mBar lower than the legal requirement…although they all said it wasn’t too much to worry about and that my boiler will still function and will be serviced. Within the last 8 months our boiler developed a fault and the pump was replaced. We then began to hear a loud noise from the pump when the hot water demand switched on and off (like water hammer sound). British gas came out again and the engineer called his mate who is a Vaillant engineer. He replaced the pump again and told me that it is a fancy modulating pump on these systems and that if the problem arose again (dodgy batch of pumps? Because it was fine until the first time they changed it) they would be calling out Vaillant as it still was within their warranty. He then informed me that his ‘Vaillant mate’ said he would condemn our system as unsafe due to the low pressure and isolate it. BG engineer pointed out that there was a 15mm gas pipe going into the boiler and that this was the problem. I decided to check from the meter and found that it is 22mm up till the point where the gas pipe drops down to the boiler from the ceiling above it (the gas pipe runs down behind the boiler and I’m sure there wouldn’t have been enough depth for a 22mm…so it looks like the installer may have decided to reduce the size before dropping down…which means a run of somewhere between 1 to 1.5m of 15mm). The BG engineers reply was simply “maybe he should have installed 28mm”.
I’m now in a dilemma, as the noise fault started not too long after the pump was replaced and is getting noisier to the point where it was at when I last got it replaced.
I’m concerned that I am going to have my boiler switched off and am unsure as to where I stand with regards to contacting the installer that commissioned this installation so long ago (the BG engineer reckons he should still have to put the work right?). The installer didn’t work for me; he was employed by the house builder, so where do I start? Also, since the pipe runs through a section of ceiling, if the pipe was to be replaced, I can only see 2 options for replacing the lot, 1) A hole in the ceiling to access the elbow that drops down to the boiler, or 2) Go in from the floor above, which is fully boarded and Karndean flooring.
The majority of the 22mm run from the meter runs round two walls of my double garage (at least 8m run with a couple of bends). If I could somehow find a way of getting the installer to come back, would it help if at least the majority run of the pipe was increased to 28mm (then there would be @ 1.5m of 22m and @1.5m of 15mm to the boiler)? I realise that calculations would need to be done, but does it seem feasible that this could give me the extra couple of mBar I need to make it compliant?
Finally (phew!!!)…how can I be sure that BG are supplying enough pressure in the first place? The development (11 detached houses) is new and I know that less than 2 year back they were digging up the road at the entrance to our estate to do some work to try and increase the pressure as it was low then.
Soory for the length of the post, but I thought more detail may help with any advice (which I would most gratefully accept)!
Thanks…Patrick
Thanks…Patrick
