Incidentally, how strict is the regulation of max 1mbar drop from meter to appliance? For example if teh drop was 2.5mbar but the working pressure was within spec for the appliance is this acceptable?
i've tested vaillants which had a perfect ratio but inlet was only 9mb
Looking at the Ri instructions it says that the gas connection is 22mm, this would mean that a 22mm supply is needed, as you cannot reduce the inlet supply
