A frustrating airblock - picture included
I have the plate off and have exposed the valve brass workings. Just unclear how to remove filter - I assume it is removed as parrot the centre thermo control but no obvious way to remove.
if it's the one in your pic then remove the screw.
On the flexible hose it's where the metal braiding connects into theplastic that the droplets are appearing. Does that sound like a seal issue?
no thats the rubber hose splitting or coming away from the metal part of the hose.
it won't last like that so change it before you get a flood ;)
seco - thanks again. Found the screw on the valve (didnt realise it was a screw as it looked like one block of metal!
thanks for your help - spoke to aqualisa and a new hose is being sent out
