A little Lead help
29 Mar 2007
London
Could someone please answer the following questions, I'm sitting a course and can't seem to find the answers
All are for the LSA reccomendations with regards to chimney flashings
1. The width of lead needed for a bossed front apron
2. Code of lead reccomended for a back gutter
3. Reccomended method of fixing soakers
Thanks in Advance
the lead for the bossed front apron should be the width of the stack plus 305mm and needs to be wide enough to provide 150mm cover on the tiles,the allowance for the upstand will vary depending on the brick courses but needs to be a minimum of 76mm,then you add 32mm for turning into the brickwork.a back gutter needs to be code5 or 6. soakers are usually just turned over the top of the lath,personally i always fix them with a copper nail.
up the tile and over the lath........gauge +lap+1inch .........every thing else done by eye :wink:
Ooooooooh this reminds me of my college days happliy hammering away without a care in the world, then I became a qualified plumber and the headaches began !
Pete
bossing :x Did most of mine with oxy-acet. Still got the torch and hoses :wink:
I did both and twas so much fun bossing a lead slate :cry:
