I'd like to go back to when I was 15, how do I do that![]()
you could try a restore to previous date, i know that it sometimes helps![]()
don't know, but if you find the answer let me know, i think that was when it all started to go horribly wrong!!
They are already ticked,As for the script erors,
Open IE -> Tools -> Internet Options -> Advanced Tab.
Scroll down thelist to the Browsing Section.
Put a tick in the box next to each of these:
Disable Script Debugging (Internet Explorer)
Disable Script Debugging (Other)
That should stop the error message appearing.
dave
It only came up when I rebooted/restarted but i just did that and message did not appear.Does the Error IM32FAX DIL NOT FOUND message still display or has that been stopped?
Help and support window fo HP invent, from Start menu, it's where I went to restore back.I am a little confused regarding the script error, what Help and Support are you using?
What are you doing to get to Help & Support and why are you going there?
when I close the window down, the internet explore script error appears, asking if I want to continue running script on the page. YES or NO
URL hcp://cn=hewlett-packard,l=cupertino,s=ca,c=us/HPQ/XPXWWPP5/PCHClientUI/Global/PCHBtnMonitor.html
if that helps
That's not safe mode. Safe mode is an option from that screen. That's the bootloader.
On a technically, Monkeh is probably correct but the OP would not have known the difference.
Does this get rid of the missusI may have worded it slightly incorrectly BUT my instuctions were correct to get the OP to get his computer to restart in the last good configuration, and hopefully get rid of his problems.
