Having rectified initial wiring problems - discounted True Radiant in Nest settings by turning it off - removed an old Pipe Stat wired as a room stat - and watched the Y Plan valve seemingly working OK - the boiler still fires up when not scheduled.
It was seen yesterday with the flame icon and 61 degrees showing on the boiler screen while making the appropriate ON noise.
The temperature would change to 58 make its way up to 65 in a few seconds and the flame would go out - repeating this cycle until the fused spur was turned off.
The display temperatures seem to follow what the tank stat and the boiler temperature are set at.
Is it most likely to be a micro switch sticking on the 3 way valve ?
If so has anyone successfully freed them off ?
Thank you
Ray
Thank you
Ray
