Hi
Couple of questions and advice needed for fitting a complete new bathroom.
It all arrives tommorow , so i have to start planning my plumbing.
I have some lead pipes to remove , one is easy , the other i doubt i will be able to remove. The easy one comes down from the water tank in the loft and can be replaced without too much trouble , the other (main) comes up from the kitchen below and runs behind the kitchen wall cabinets and up through the ceiling into the bathroom floor, it is also buried in the plaster work along with a massive compression fitting , i'd rather leave this alone and use a "leadloc" type fitting above the floor in the bathroom and switch it over to conventonal pipework from there.
Is this ok to use a leadloc fitting, are they reliable ?
All the plumbing in the bathroom is a complete mess , so it all has to come out and be re-done. I've never used copper and solder and notice push fit copper fittings are available.
Which is best ? copper push fit or the plastic push fit systems ?
Finaly , switching over to a wall hung toilet form the existing. The soil pipe is the original cast iron pipe from the 30's or 40's , will modern pan couplings marry up with this ok ? or will i have problems ?
any advice much appreciated
