If you want rigidity I'd suggest you avoid soldering the joints as the heat of the soldering will anneal the copper and soften it. Gluing end-feed fittings is probably your best bet.
Just learn to solder, it's very easy to do, you just need to invest in a blow torch, length of plumbing solder and a tub of flux. The key to it is to be clean and grease free before you even start slapping flux on. The flux does some cleaning while it's hot, but it won't get through thick oxidation. Soldering pipes together is a piece of pish. And with more practice you can make joints look nice too.
What size is this table and is it likely to be subjected to kids or heavy loads? 22mm copper tube of any significant length may need an internal dowel for increased rigidity.
Sand ballast won't stop it bending, merely stop it kinking if it does bend. That's why sand is used as a bending medium.
Providing lengths undergoing bending forces are reasonably short, the strength of a soldered copper tube space-frame is quite surprising.
