ABS waste branch in walls?
  • Thread starter Thread starter NotSureAboutDIY
  • Start date Start date
N
NotSureAboutDIY
anyone know what the best method of embedding ABS solvent weld waste pipe is?
ABS is commonly used for waste pipes where the fire resistance of PVC is not required.
I would not recommend burying it in a wall as you will serious effect the structural integrity (with a standard brick/block wall)
Back to school Gasguru :lol:
ABS application Guide.
Acids and Alkalis, Air conditioning and refrigeration, Biotechnology, Chilled water, De-mineralised water, Effluent treatment, Electro-plating, Film processing, Irrigation, marine/brine, Pharmaceutical, Potable water, Semi-conductor, Slurries, Swimming pools, Water and sewage treatment, Water industry.
An expensive way to run a waste pipe.
Interesting :lol:
Thats PP (polypropylene) not ABS ( Acrynonitrile Buladiene Styrene ) :lol:
doitall said:
Gasguru said:
WHAT are you on about :?: :?: :?:
Both links are ABS pipe
Yes and both products are PP not ABS
Even the page that says :
A.B.S. Solvent Weld Waste System Grey, Black, Brown & White (50mm Grey & Black)
BSI Certificate BBA Certificate COSHH sheet Product Dimensions
BSEN1451-1:2000 ABS Waste Pipe & Fittings Waste Pipe ABS
and the other page that says:
Waste Branch
Solvent-Weld Pipes & Fittings ABS
what the f***. ABS is ABS or is someone saying ABS is in fact polybol**ks or another or are you all just confusing me on purpose.
