ABS waste branch in walls?
  • Thread starter Thread starter NotSureAboutDIY
  • Start date Start date
ChrisR said:
its the sort of engineering problem Ive not looked at since I was in uni and reminds me why I left
its the sort of engineering problem I have looked at since I was in uni
and can do the little bit of calculus to work it out if I need to.
mwhahahahahaha the "little bit of calculus", are you having a laugh?
a flowing/changing/diminishing heat source, moving at variable speed, down a variably surfaced temperature gradient, passing through various shaped waste pipes and cold water traps, needs a little bit of calculus, if you can show me on paper an accurate thermodynamic equation to that, I'll tip my hat to you!
I mean for a start the co-efficent of thermal conductivity assumes steady state conditions.
Give it room, or regret not doing so!
yep room is no bad suggestion and that has definately been taken on board
However I wont be running 400 boiling kettles down it either :-)
Thermodynamics isn't involved, and the conductivity is sufficiently constant in the temperature range being considered not to affect the result. Allow half a centimeter per meter.
OK ChrisR, thats a crude method to estimate expansion.
the rate of thermal expansion only gives a simple expansion vs temp change ratio, it says nothing about what energy over what period of time would be required to create that temperature change!
as for thermodynamics not being involved, well thermodynamics is just a the branch of physics designed to help think about thermal systems, Id say your application (just use co-effiecent of thermal expansion and assume 70-90 degrees) doesn't use much knowledge of thermodynamics, thats a failing not an advantage.
Id say Ive got an open system, with heat, work and matter flowing across the system boundary (waste into the stack mostly)
I think expansion is likely to be less than you estimate due to due to:
1. the inherant resistance to heat increase/insulating property of the material will prevent heat change and therefore expansion.
2 likely rate of flow and thermal gradient, the pipe will never be totally full of matter at 70 degrees C for any period of time and will typically be used for only 2-3 minutes at a time maximum.
3. loss of energy to the first 2 thirds of my system from the source, before we even get to an expansion critical area.
My guestimate says I could run hot water from now until forever down the waste and the walled section is unlikely to ever get to 50 degrees C.
As I said I'm not likely to want to run the numbers fully on this because (despite your suggestions that this would be a simple problem to prove/solve) I'm pretty sure its a non trivial task, my idea is to suck it and see as they say, place the pipe, run hot water for half an hour chucking in the odd kettle and washing machine run and have a nose at how much expansion I actually get, I'll let you know what I see...
Not really, it's more specific than that.
Took it for 2 years as part of one of my degrees, ta.
Have worked with fluids in industrial pipelines (as well as domestic...)
Have measured temps and movements in pipes such as yours, and seen effects of not allowing enough space.
Allow half a centimeter per metre
and stick to the day job!
Nope, it's more specific than that.
Have worked with fluids in industrial pipelines.
how odd I did 2 years during my admittedly failed degree too
http://en.wikipedia.org/wiki/Thermodynamic
in essence thermodynamics studies the movement of energy and how energy instills movement.
I'd apply that to this situation, I guess thats where we differ.
obviously there are many branches, laws and rules,
here are a couple I'd find integral to this issue
http://en.wikipedia.org/wiki/Transport_phenomena
http://en.wikipedia.org/wiki/Heat_transfer
have a read maybe you need the refresher more than I do. :-)
as for the stick to your day job comment, look I appreciate the advice an all, but honestly my waste pipes arent ever getting near 70-90 degrees C ever. whilst 1/2 cm per meter doesnt sound unreasonable, it is an almost entirely gut based calculation isnt it? I'll stick to my method, set it up, measure expansion and design accordingly. As I've said before thanks for your input but maybe you should work on those people skills a little. :-)
Nope. Already told you.
No you really havent, you've posted a single figure 1/2cm per meter, that appears to be usable and accurate regardless of length of run, thickness of pipe and angle of drainage, Ive got no working other than use of the co-efficent of thermal expansion (which isnt even on the page you linked) and a lot of abuse when suggesting that the accurate calculation of such a thing may be a little complex!
No need to ask anyone who knows, then.
Knowledge isnt something I often seek, I look for understanding, I dont want an "answer, now go away and do" as these situations are usually the root of errors.
As I've said before ChrisR your stressing of the importance in the difference of thermal expansion properties has been gladly accepted and possibly will prove a life save on this project so lets not confuse that!
Maybe I should waste less time on people who aren't worth the trouble.
Maybe we should both spend less time trying to stress how smart we are and more time solving my drainage problem :-)
Its a shame if my replies have given you the arse or put you off helping others, your experience and advice is valued, I'm just suggesting being a bit more open about why you advise and how you come to your conclusions would be reet helpful to the question-ee!
thanks again for the advice, stew
Jeez, look, this is a forum for advice, not limitless education.
It's nothing to do with being smart, it's all easy when you know the answer because you've been there before. Yours is a trivial matter which doesn't warrant pages of words - certainly none further from me.
well its a forum, what people do with it is up to them, in your case I'll thank you for the advice, if not the education.
