When ever there is a power cut, (I have had two in last 4 days) my Accenta G3 alarm sounds off really loudly, because there is no power the keypad is dead. I have to wait for the power to come back on to silence it.
You will have no further effort to make in completing the job with anew battery, but can do it at your leisure and with the old battery available to get a suitable replacement.
I have located a large box in another part of the house, I assume that this is where the battery is located. It has an isolator fusebox below it.
The alarm box cover is held on with a single star headed screw.
If I remove the cover to access the battery, will the alarm sound?
Yes.
Turn off mains supply to box. Open. Alarm rings. Enter user code. Change battery.
If you don't know code, remove battery and the bell box battery will run down in 15-20 minutes
After having the 'problem & cure' explained to you, I would suggest that you are not the type of person that would be able to cope with an alarm system.
Remove it.
ps. I've had a bad day, but the above still stands.
It's the insanely loud noise in the wee small hours that I and surrounding neighbours can't cope with!
It's more that I don't need an alarm, than I can't cope with it. I didn't have it installed. We inherited it with the house, along with a service history but no instructions. Having never had a house with an alarm I am unfamiliar, rather than incompetent.
It was fitted on 25/01/13 therefore has lasted less than 15 months.
This seems to fit in with the pattern of battery life according to the service history.
Before I shell out on another one, I would value any relevant comments.
Thanks,
David.
Check charging voltage from panel with a multimeter set on dc range...should be around 13.8 v dc ..... If no voltage check battery fuse ... Been to many jobs where someone has changed the battery but not checked the fuse..old ade panels do tend to go up to around 14.50v dc any higher will cook the battery.
I'll give it 24hrs, then I'll cut the power myself. If the battery isn't knackered by being drained it should have re-charged enough to cut in and I should hear no alarm. If I hear alarm, to Maplins I shall go on Thursday to replace battery.
You will need to replace the battery in panel because with a new one it will hold the system powered up for as long as you are away and the outside one won't go off. Good luck!
