Access to light circuit in floor - options
8 Jul 2008
Derbyshire
I require some alterations to a lighting circuit.
The electrician as part of the quote mentioned access to ceiling via loft.
I thought I'd make the job easier by preping the area - pulling up carpet etc.
However, it soon transpired someone in the past took a belt and braces approach to flooring the loft. Each large format board that makes up the floor is secured by a ton of large tacks/nails. Each board is very tight up to the next. So getting them up is nigh on impossible!
Any thoughts to access options? Cutting a hole at the required points is one of the few I can think of. Is there anyway to cut a hole with an angled bevel so that a section can be removed and reinserted like a plug?
Ahh brilliant. Just the solution I imagined.
In that case, I'll just leave the carpet pulled up as I expect an electrician to have such a tool to hand.
I thought pulling up the boards would have been made everything much easier. I hoped they had used screws, but no, many nails.
And those boards are T&G on all 4 sides. Horrible. Even if they were screwed, so would you be.
I have the tool, but have currently run out of the plugs to go in the holes...
