Acoustic properties of plasterboard and Celotex
2 Jun 2003
Hi...I live in a flat and I am planning on replacing the carpets in hallway and living room with engineered wood flooring. The issue that I am facing is with what to install under the new flooring in order to comply with Part E. The existing subfloor consists of 3 layers of floating sheet materials (20mm plasterboard, 50mm Celotex and 18mm T&G chipboard flooring) sitting on 18mm plywood and timber joists. Below the plywood decking is 200mm insulation wool.
My questions are... what are the acoustic properties of the existing floor structure and what level of acoustic insulation do I need with the new flooring?
Many thanks
Remove the carpet, run up and down with boots on, and see if the neighbours can hear it.
I would expect a modern building to be designed so that the acoustics do not depend in the final floor covering.
Do you have any lease terms or similar about floor coverings?
I think it depends on the leasehold terms. Many years ago I rented a flat that had (cheap) laminate flooring and one day the building management sent a letter asking us to remove it as it was not allowed. (We forwarded it to the landlord who never did anything about it...)
The laminate or the letter?
