You should lay a vapour control layer over the celotex. To quote from Celotex's installatiion guidelines based on over slab installation...
"Lay a polythene vapour control layer over the insulation to minimise the risk of condensation and to prevent liquid screed migration"
Just go to Celotex's website and there are technical data on how thick the insulation should be. There is a calculation you can do based on the area of the extension and the exposed internal perimeter.
You should be looking to acheive a U-value of 0.22 but as its a conservatory (I assume you have kept it seperate from the main dwelling by external doors) then it doesn't require regs and therefore you don't have to stick to the required U-value, although you should where possible.
Mike
Mike
