2kW electric blanket?
So can you advise on which manufacturers make leads with plugs on then which can withstand the heat generated in a 13A BS 1362 fuse passing 20A?So cheap extension leads and more importantly, improperly fitted rewirable plugs, can fail badly.
That does not make daisy-chaining extension leads dangerous, merely buying cheap, s**t ones and not checking the plugs dangerous.
You absolutely HAVE to be able to do that if you are going to tell people that it is safe to daisy chain.
If you cannot so so then you absolutely MUST retract your advice posted on 11th January 2013, 14:56.
There are no appropriate tests.I use Belkin usually and have never had an issue. I might do some 20A load tests (probably with low voltage DC) out of boredom some time, but I trust Belkin, as a reputable (mostly) name, have done the appropriate tests.
No it isn't.No, I don't, it's not my job to police the quality of goods sold in this country.
which is complete, and dangerous, b****cks.They're all fused anyway, so there's no risk of overloading.
You just don't get it, do you.See above.
YesWould it be worth changing the 13A fuse in the main extension lead (the one that connects the others to the mains socket) to a 5A fuse?
Indeed so - that would effectively neutralise all of BAS's concerns/arguments.YesWould it be worth changing the 13A fuse in the main extension lead (the one that connects the others to the mains socket) to a 5A fuse?
No different. The 100A fuse, when new, could probably take cumulative loads (ie add one at a time) up to a total load of approx 120A. There is a degrading effect with high loads, so I'm told, so an old fuse would probably rupture at loads just less than 100A.So its a known problem that a 13A plug top fuse cannot be guarenteed to adequatly protect a 13A plug/lead from overload as it can pass 20A for a sustained period.
How about when the situation is scaled up? how would your 100A consumer unit main switch or RCD fare when protected by a 100A cutout fuse and subjected to a sustained overload, not immediatly causing the fuse to fail
Not at all - by 'neutralising your concerns' (which are valid concerns) i meant 'make the reason for those concerns disappear'.You make it sound as if I've made it all up.
Yes, but in the context of this discussion, 20A is not necessarily either 'very unusual' or due to a fault. If the 13A plug is on the lead of a multi-outlet extension lead, there could, in theory, easily be several 'moderate' loads plugged into that extension, with their currents (all of which were going throuigh the single plug on the lead) totalling 20A (e.g. 4 x 5A loads).PS. A 20A current means that the appliance is drawing a load of 4.5Kw. No appliamce with that loading by design should be connected though a 13A plug. Therfore, a 20A current must be a very unusual fault ....
Kind Regards, John
