Added Inhibitor but still getting hydrogen in radiators.
Could be youre sucking air in and that’s starting it gassing. Bob
Sentinel do a heating water test kit, often £10 on Amazon. You collect a small sample of tap water and heating water (from a bleed valve), send it off and they provide a report. System does need to have X100 (only) in it to produce a report with anything useful on it though.
UPDATE 5th April.
The good news:
- the build up of hydrogen in the radiators seems to have stopped
- had the boiler serviced he said it was in very good nick including the heat exchanger
The bad news: That was 10 days ago and the boiler pressure has since dropped 1 bar and I have topped up. This wasn't happening before.
So a leak? But I can't find anything and there is no air getting in the system that I can tell. Seen lots of threads on this have checked rads, visible joints, ceilings, looked for drip on outside pipe etc... Nothing.
Expansion vessel was reportedly correctly pressurised.
He did do some scrubbing thing on the heat exchanger? Could that have aggravated anything? Should I get someone back for another look at the boiler???
Should I start pulling things apart in the non visible areas to look for leaks?
Thanks as ever...
