Hi
I have just moved house and find that there are no electrical mains sockets in my hall way, the only electrical feed is to the central heating boiler that is a fused switch. Can I add a double socket spur from this point? Its fitted into the wall, so I am presuming that it comes from the fuse box.
Alternatively, I would have to run a cable from the fuse box round the back of the downstairs toilet and through the wall, approximately 4-5 metres. If I do this should a conduit always be used or can I just attach it to the wall. The previous owner has already run a cable without a conduit in the same place to feed the garage from the fuse box which is situated in the downstairs cloakroom/toilet, about 4 metres away from the toilet.
Also as an another alternative could I run a cable from the existing cable (above) by adding a junction box to this cable to reduce the amount of exposed cable in the downstairs cloakroom/toilet and then put it throuogh the wall to add my double socket?
Hope there are not too many questions to answer but I need a solution.
Many thanks
Kathryn
Many thanks
Kathryn
