Adding a heated towel rail next to an existing rad
7 Nov 2024
Hi I am thinking of adding a heated towel rail to my combi boiler system I was thinking that I could T off the flow and return pipes going to an existing rad in the bathroom
any thoughts?
1. Provided the existing radiator is not short of hot water flow, no reason why not.
2. Therefore, if the radiator is not abnormally large (unusual for a bathroom) and is either:
2.1 Directly connected to the 22mm "spine" of your central heating system. OR
2.2 Is only connected to 1 or 2 other (ordinary) radiators with 15 mm pipework THEN
2.3 You should be OK.
