- Joined
- 11 Sep 2007
- Messages
- 769
- Reaction score
- 31
- Country
Hi Guys,
Unvented cylinder running house, house has two en-suites with showers, so there is a hot and cold feed coming off the cylinder somewhere up into the above floor to run the showers, each pipe has an isolating valve on, so no problem cutting off the supply.
Need to fit a shower in the bathroom which is behind the cupboard with the unvented in..
My question is this, can I isolate the hot and cold of one shower and tee into this, through the wall and run a third shower, will be really easy to do, and the two showers will never need to be run at the same time so I cant really see any problem, just after some clarification.
Look forward to your thoughts on this one.............
Cheers
Cheers
