If it were flat twin, then I agree that would not be hard. However, it looks twisted, not flat, to me, and that would make it significantly more difficult. If I had 'followed' a conductor around all those twists, I think I'd want to get my meter out 'to confirm'!
In most cases I think the live is also the core that terminates at the first bulb, whereas the neutral passes by right to the last bulb, usually 20 bulbs
That may be common, but since there is no compelling reason why it has to be wired that way around, it clearly would not be safe to rely on the fact that it has!
Thanks. Just to be sure, do I take it that the last photo (on its own, in the second post), bearing the label, is of the box that the lights came in, rather than anything to do with the actual lights?
Not necessarily. As has been discussed a "double-pole" switch (such as the couple I linked to) would be OK (provided that it had adequate clamps to stop the wires being yanked out), since it would switch both wires (so you wouldn't need to know or work out which was live).
