Adding cold feed for dishwasher
23 Feb 2005
Surrey
Going to be installing a dishwasher soon. Our existing cold feed under the sink is in the shape of a 'F'.
The bottom 'stem' of the F is the isolating valve.
The first 'bar' of the F goes to washing machine cold feed (with shut-off valve)
The second (top) 'bar' of the F goes to the cold tap on the sink.
I intend to remove the washing machine connector and add a T before it. Like this one. Then put the washing machine connector on the end of the new T.
Is this as straightforward as it sounds or am I overlooking something?
Also will I need a new section of pipe between the 2 hose connectors or will they fit together somehow?
you will need a short bit of 15mm pipe to go between the old and new valves.
you havent metioned what you are going to do with the waste water though
Thanks for the quick reply Breezer.
The waste isn't a problem, the dishwasher will be almost next to the washing machine which discharges straight out into an external drain, so I can share that pipe. There also an unused washing machine outlet on the waste pipe of the sink I could use.
I have ptfe, will I also need jointing compound on the compression joint? Or is that optional?
i never use either on compression joints.
the olive is there to stop leaks on the nut side and the dishwasher hose should be hand tight only
