Been getting on with work on my parent's hose which they persuaded me to buy.
Heating system is standard single zone rads to a Baxi 105HE Condensing Combi boiler.
Checking out its all working - found the wall-mounted Honeywell thermostat had no effect on the boiler, the system, in fact, being controlled by the timer control on boiler and the heating temp dial on the boiler.
The system is under a service contract with British Gas (who did annual service & safety check in Jan) so called them.
They explained that separate thermostats are mandatory since 1982 so if faulty it would have to be replaced.
On inspection they found it was not wired in the boiler (yellow wire link across where stat would be wired) ... and no cable there, assume it must have been 'cut out' when the previous non-combi boiler was replaced 5 years ago. Honeywell stat certainly used to work with old boiler (simple bi-metal type)
I did ask how it passed the annual boiler & controls service if it doesn't work - no answer on that.
It would not be easy or neat to run in new cables .... so I have 2 options.
1. Fit a basic Remote wireless thermostat-anybody know of a simple one?, don't need programming options as there is a programmer timer on the boiler.
British gas are also preparing a quote, for this - though may do it myself.
