Adding isolation valves to radiator dog legs
Ok, all rads isolated at both sides and I've also isolated the flow and return at the boiler, which is off, of course... Well, the heating is off anyway. Plus I released the remaining pressure in the system by opening the bleed valve and opening both valves at the bottom... And closed them again. I have my new bits of pipe with valves connected and I'm heading under the floor.
Wish me luck!
Barely a drop spilt! The only water that came out was the little dribble in the bits of pipe I was removing!
I suppose I better turn the heating on and check it's not leaking before I open up all the isolating valves on all the rads again...
