Indeed - and you wouldn't necessarily even need conduit.There is an airing cupboard, yes. There's no sockets in the cupboard itself, but there is a double socket on the other side of the wall in a bedroom. I suppose I could take a spur off this, through the wall and run a cable up some conduit inside the cupboard into the loft.
Yes - as you've been told, provided there is a 13A FCU before you get to the loft socket, you can connect anything you like to that socket feed (your 3A FCU, further sockets or whatever).If I did this, would I be able to install a socket in the loft, plus fit a 3A FCU for a lift light? Can I do both off a single spur?
Kind Regards, John
