Thanks for that.
I have done the measurements (sheathing and conductor) and indeed it appears to be 4mm.
Sheathing is 11.9x6.25mm (snug) and it's multistrand cable at around .85mm in diameter per strand (or as near as I can measure it) which adds up to 2.87mm right? It may be slightly less as I didn't want to compress the bundle.
The sheathing also has the number '4' on it's own along the the 'Basec BS6004 (2006)' data.
To do this with stranded cable::
Unwrap the strands so you have just one strand
Measure the diameter of the single strand, halve it to get the radius
Work out the area of the single strand ( πr² )
Multiply by the number of strands
A very rough way to ESTIMATE the CSA is to measure the outside of the cable sheath (with the insulation). There are guide figures and more info here
