I built a house approximately 2 years ago. We went for the Grant Vortex outdoor combi boiler 26kw.
The plumber at the time has done 22mm runs for hot water and then 15mm reducing tees to the shower, taps etc. Reading the grant manual it says that it all be done in 15mm. At the time, i asked him to run pipes to upstairs for when i convert the upstairs to a living space.
So upstairs i have 2 x 22mm pipes for hot and cold water, is it better to reduce this to 15mm at the earliest point upstairs?
Also, according to the user manual the radiators should be in 22mm and then 15mm to radiator tails. He has run 2 x 15mm pipes to upstairs for flow and return, should i increase this pipe to 22mm at the earliest point upstairs?
This is all in copper
Many Thanks in advance
