I have a none pressurised central heating system and want to add another radiator at ground floor with floor boards.
This system is a pain to drain/refill, as it doesn't have an up and a down pipe from the tank, so I have to use a vacuum pump.
Anyway, I hope to cut one side of the radiator feed and quickly push a bung on a rod into it, Then feed an open stop valve over the rod and fit it on the pipe end, then pull the bung though the valve and quickly turn it off. Does this seen feasible?
Cheers, Camerart.
Cheers, Camerart.
