Don't do it this way:
Turn off the heating.
Wait for the pipes to cool.
Cut the pipe (proper cutter)
Thumb over the end.
As my old pipes are steel, the olive didn't fit, so messing about allowed hot water to come out which was too hot to hold. I ran to get some thick rubber gloves, which allowed air into the system.
Anyway a fiasco!
How to do it:
Have wet emery cloth and a taper tube handy. I used a blocked silicon nozzle from a gun.
Put the olive, then the nut onto the taper tube.
Cut the pipe.
Stick the taper up the pipe.
Slide the nut onto the pipe, then the olive. If it doesn't fit, clean the tube till it does, then slide it on.
Close the isolating valve.
Pull out the tube, and push the fitting on, the water will immediately almost stop.
Tighten the nut and job done.
I didn't want to have to go up the attic with the vacuum pump (to old for all this) Getting the air out took days of bleeding the little bubbles that would work round each day.
Anyway, it's all working again, and I did add a bottle of Sentinel 100, to the radiator.
I'm pretty sure that if I called a plumber, they wouldn't do it, as it needs a new system (This one 30 years old).
Hope this helps. Of course you could have a freezing kit if you choose, but this way is easy!
C.
