JB's are a likely place for a fault to occur, as they are a weak link in a circuit. They may also throw certain sensitive tone tracers and distance/fault analysers off. But this does not normally apply to domestic set-ups.
It is said that JBs must be accessible. Because, amongst their other sins, the create a weak link in a ring.
But when extending a ring the alternative (apart from relaying an entire length of cable) is to extend from a socket.
Isn't the socket then a weak link in the same ways as a JB is.
I guess it is down to the fact that they are both weak links that when needing to be tested must be accessible. In the case of sockets they are definitely accessible whereas JB give the option of being hidden away under floorboards.
I've got loads of JBs stuffed away in inaccessible places because there was no alternative.
