I am at installing a second shower. The shower fitted at the moment is a 9.5 kw and the one I want to add in an additional shower is a 8.5kw. At present there is a 10mm cable which runs from the main consumer unit to a 45amp fuse box thereafter a 6mm cable which runs to the shower unit. I want to replace the 45amp fuse box with a 63am 30ma RCD unit to run the two showers from. The question is will I have to replace the 10mm cable which runs from the main consumer unit with a higher rating and if so what rating? or is this not viable.
Hope this makes sense.
