I meant mine rather than yours.rambling..come on ritchie was only trying to educate you ever so slightly ..and have a laugh along the way
I’ll keep my eyes ever so very peeledno doubt i will post a few errors along the way and someone will point these out to me and have a wee joke to..i hope..
everyday is a schoolday
Well that’s very interesting, I wonder what changed or maybe nothing did I’m familiar with SBR as a waterproofer in rendering but I’ve always stuck with APD as a primer for gypsum plaster when tiling, after all I'm usually responsible for that as well; thanks for that.Bal have only recently changed the spec advising that SBR can be used on plaster with cement based adhesive. Personally I prefer APD, SBR is just a deluxe PVA, I don't use it
I agree that there seems to be something very wrong if you’re only getting 10 minutes pot life.Pretty much wasted my first bag, 10 min working life just not enough.
The trick is to plan your tile layout before you start, lay only full tiles first & then prepare your cut tiles individually before mixing the next batch; I number them & lay them in one hit; don’t attempt to start cutting tiles while you’ve got addy in the bucket. It may seem obvious but if your addy has a pot life of 45 mins only mix up enough adhesive that you can use within, say, 35 mins which will give you enough time to clean off your tiles & wash down your bucket & tools ready for the next batch. Always clean your bucket & tools thoroughly, leaving deposits from the previous mix will send the new mix off more quickly. How many tiles you can lay in 30 minutes rather depends on practice & experience.How do you pro's manage to actually get so many tiles up in a day when you've only got 10 mins between mixes?
Find a stockistr of Schluter products:-
http://www.schluter.co.uk/tile_trim.aspx[/QUOTE]
Cheers, but I've already got part of the trim up (Genesis).
