Exactly, I've done it hundreds of times. Jack up one side with the trolley jack, put axle stand under. Car is well lopsided until I do the same with the other side. Sometimes if only doing one side, it's lopsided for the duration of the job.
trazor said:I do not see any problem with jacking one side of the car only, this is what you do when you use a normal jack to change a wheel......
Stivino said:"but if you use this how are you going to change a wheel?"
You wouldn't use it to change a wheel. you'd use a jack.
breezer said:but if you use this how are you going to change a wheel?
you cant because the car is resting on the wheel you just drove on the ramp
you use car ramps to work under the car, so one will be of no use, you need 2.
breezer said:
DIYspanner said:One of the case studies on the course is for a famous vacuum cleaner,
which took well over thousand attempts to get right apparently.
...Pair of strong well made height adjustable car ramps, shown in photos at min height & at max height. These are brand new. New steel, bearings, nuts & bolts etc.
A bit similar in design to the Kwiklift Mk2 models sold in the 80's, but fabricated with 50% thicker steel for the main frame & lifting assembly - making them stronger and more stable.
Far superior to the old wobbly Mk1 models, (more often seen on ebay), which were basically a scissor jack bolted on to the end of a standard car ramp.
These have a jacking system built into them, lifting the entire ramp from a minimum height of about 21cm (8") to a maximum of 40cm (15½") approx . Adjustment is by a 24mm bolt which you can turn with a spanner or a 24mm socket. You can raise & lower them in seconds with a decent reversible power drill or air wrench.
At their maximum they are around twice the height of ordinary ramps, making it far easier to work underneath a vehicle. Ideal for garages, car restorers & serious DIY'ers. Maximum tyre width is 215mm...
