I've just (today, in fact) had a new line fitted by OpenReach, currently just being used for the PostOffice telephone service - new drop-cable and all, as the old line was defunct, and certainly hadn't been used by me in the last 3 years. At some point relatively soon, I'm probably going to move to Tiscali's phone (including line rental) and broadband service at £14.99. But...
If I enter one of my neighbour's phone numbers, the BT Wholesale checker states the following:
...if I enter my (new) number for my new line, I get the following:
Tiscali's own predictor is even worse. Neighbours:
...me:
So...quite a difference. Same exchange is listed as that of my neighbours, we're even connected to the same pole!
Is this checker just a trival check on phone number? Are phone numbers recycled, so might I be getting a guesstimate based on a number that was once further from the exchange...or do new numbers get some very base level estimate by default?
Your exchange is ADSL enabled, and our initial test on your line indicates that your line should be able to have an ADSL broadband service that provides a line rate up to 2Mbps.
Our test also indicates that your line currently supports a potential ADSL Max broadband line rate of 7Mbps.
Your exchange is ADSL enabled, and our initial test on your line indicates that your line should be able to have an ADSL broadband service that provides a line rate up to 1Mbps. However due to the length of your line the 1Mbps service may require an engineer visit who will, where possible, supply the broadband service.
Our initial test on your line indicates that your line may not support a reliable ADSL Max broadband service, with current technology. However, an order for 250Kbps broadband speed will still be accepted, but an engineer may need to visit who will, where possible, supply the service.
We estimate the maximum speed your line can support is 5.5Mb.
...me:
We estimate the maximum speed your line can support is 1.5Mb.
