Hello all,
recently moved into a new flat with an ADT 3200 alarm (which I understand is a rebranded Scantronic 9800). The cover over the panel came off when I bumped into it (unhelpfully loose screws), and set off the alarm I couldn't find the access code at the time, so pulled out the wires to the battery and the fuse. Subsequently found the access code, put everything back together, but have been left with an error code - 5r (or probably sr, system reset?).
I'm not planning on having it monitored, just a bells-only, and am loathe to shell out not insignificant amount of cash for someone to reset it for me. Would anyone be able to assist with resetting the system with whatever access code I would need to use? Any help would be much appreciated!
Thanks to all,
Marc
Thanks to all,
Marc
