Thank you sparkymarks. Does the alarm box have a trip switch? Will it sound the alarm when I remove the cover? I want to minimise the risk or length of time the external alarm sounds since I do not want to upset the neighbours.
The prevoius owner insists he has given me the right code. I enter it and press A but there is no response. I have tried pressing clear first as well. I also tried entering the wrong code once to see if that gave a response ( hoping it would not set the alarm off which it did not). The power and day lights are both on. A light on a movement sensor flashes when I move in front of it so the system seems to be enabled. It used to be connected to the telephone line with a connection to the Police. This was removed by the previous owner since I wanted to change the phone contract. Can you think of anything else I could try or am doing wrong?
The system has a fairly resent service sticker on it so it should work. I am reluctant to call the company out to fix it (assuming something is wrong) in case it turns out expensive. They quoted £105 + VAT for the first hour and it could take longer to reset and reprogram the system if it is working. Could there be a master switch to disarm it or would that give a code on the panel? I guess the keypad could be faulty but it used to work just before I moved in. The previous owner used to set it after each viewing.
