ADT Galaxy 16 Plus overcharging backup battery
Hi, I think you posted on my profile. I didn't receive a notification for that.
I wouldn't bother trying to adjust the 16+ board. It's likely a cap has dried out and caused the voltage regulation to go off. If you really wanted, you could start replacing caps or testing with an ESR meter, but the 16+ is so old, I wouldn't advise spending any time on it.
Something like the FX20 will be a decent replacement and will work with your existing wiring and keypad / other devices. If you're thinking about things like automation, then jump to the FX50. I normally sell the FX100+ for use with home assistant or other MQTT based integrations. If you have no plans for automation, then the 20 zone panel will be fine.
Hi Galaxy Guy,
Yes, Sparkymarka recommended you. re the above. Brilliant news, I have been wondering about the FX range, I think I will go with your advice & start looking, something which my son can use for automation, Thank you very much.
