After watching the handbags flying for the last 24 hours, I'm going to type something, but only because I reckon I had a phone conversation with the OP a couple of nights ago. Usually leave the fist fights and happy-slapping to my kids, but this looks too good to miss.
I am not a plumber. But I do have a thermal store which I'm more than happy with.
Points...from a non-heating engineer...
1. Gledhill (researched from the internet only) have circuit boards and god knows what else on them, designed to make them more efficient. Advance has nothing, other than a cylinder stat(or two). So immediately the store reliability takes a step forwards. And Gledhill plc goes t1t$ up, in a cloud of sludge and expired circuit boards presumably.
2. Your store is only 140 litres, so boiler buffering wouldn't be brilliant on the space heating, and with a coil (I'm guessing again) rather than a plate heat exchanger, hot water supply may well be dodgy in the colder months, whether Gledhill, advance or anything else. Due to the small size, and potentially small surface area on a small coil, store temp will have to be way up above an unvented or vented tank of hot water to get decent performance - again, I'm not a plumber, I'm just guessing here.
3. As it's a new-build, I'm going to guess again and I reckon the reason your home has a thermal store is because of cost, and cost alone, because performance/size and spec-wise, it's maybe not so good as a decent combi would have been? A tank of any sort plus a boiler should logically always be more expensive than just a boiler, surely, unless corners have really been cut!? Builder won't retro fit a combi because it's admitting failure and would cost a fair bit more to rip out a perfectly good system boiler than swap stores over.
If it was me, and the space was available in the airing cupboard, I'd spend extra over and above what the builder will go to, and either
1 - swap out to a combi OR bigger unvented cylinder OR
2 - spend extra on getting a bigger store, of sealed system design NOT openvented, with twin cylinder stats (those extra sensor pockets) and a better (plate not coil) hot water system
Bear in mind to repipe to fit a different brand of store will involve no more or less work than upgrading to a bigger store with better hot water performance, as all the connections are likely to be located differently on the store. And swapping to an unvented would probably be very similar cost-wise - initially.
Changing boiler to a combi would be more work, more costs, more hassle for the builder.
So I'd go with option 2 - spend a bit on top of what the builder will allow, as it won't cost him any more in ££ or in extra work to fit, but you may get a better performing, more reliable, simpler store.
There - and I never insulted anyone
