Advice if poss' please?
16 Feb 2007
Hi
We have just had our windows replaced with doubled glazed. I have installed tharmaline boards (onto single block) to all the walls and can now finish around the windows.
My question (if I can explain correctly!) is that the boards will create a small recess to the window, what is the best way of finishing? Should I add a cill or will the plasterer simply make good?
Hope this all makes sense and appreciate any help?
Cheers!
Not entirely sure what you’ve done; have you installed Thermaline to the wall face or in the reveals or both? What do you mean by “single block”?
Again I don’t really understand what you’ve done; where & why is there a recess? Unless tiling, it’s normal to fit a cill board before plastering (or boarding) are you not having a cill board?
A picture would help!
Hi, thanks for reply!
OK the windows are about the same width as the blockwork so the fit is relatively snug with no recess inside. Once I add the therm' board this will create a recess of about 30mm
Does that make a bit more sense?! :confused:
Are you sayig the wall is just 100mm blockwork & the inside of the window frame is flush with the inner face of the blockwork? Is this an inside or outside wall?
Hi again
I have posted soms pics which I am hoping can help?
//www.diynot.com/network/Rusty10/albums/
As I mentioned once done I would like to add 27mm therm' board to the inside and this will then create a slight recess to the window.
What is the best way of finishing? Cill, plasterer etc...?
Thanks again :)
